07-27-2010, 12:08 AM
Senior Member
Where does a Spec E30 fit in IT?
I know I could try and figure it out on my own, but where does a NASA Spec E30 fit under the IT rules?
Or DOES it fit under the IT rules?
Got a guy that wants to run Barber...
__________________
Butch Kummer
Atlanta Region Competition Director
2006,2007 SARRC GTA Champion
07-27-2010, 12:24 AM
Senior Member
spec e30 is all 325i or 325is right? that should be ITS. the 325e is the ITA version.
__________________
Travis Nordwald
1996 ITA Miata
KC Region
07-27-2010, 12:26 AM
Senior Member
I *think* that they end up being an very low-spec ITS car. There are a few things allowed that would make them expressly illegal, however - assuming they are done (e.g., engine mounts, removal of heater core).
07-27-2010, 09:48 AM
Senior Member
Thanks, guys. I'll tell him ITS and if he wins (highly unlikely) we'll deal with it at that time.
__________________
Butch Kummer
07-27-2010, 10:06 AM
Senior Member
Scanned the rules. ITS illegal would be:
1. No heater core.
2. Sway/subframe mounting reinforcement.
3. Engine mounts.
4. Looks like they can remove front panels to get cool air to the stock air box.
But, have to use stock ECU, stock dampers, spec exhaust, etc.
Can't see one winning but you never know.
__________________
NC Region
1980 ITS Triumph TR8
07-27-2010, 10:50 AM
Senior Member
Jeff is correct. In addition, spec tire. Biggest issue would be motor/trans mounts (dammit  ) as they do allow solid. However, place him in ITS...even though he could go to Hoosiers and a programmable ECU, the suspension package is going to keep him out of the top spots.
However, you might suggest he wave points to prevent and questions. Chuck
__________________
Chuck Baader
BMW 325e ITA
Racing on Social Security
07-27-2010, 10:54 AM
Senior Member
Originally Posted by chuck baader
However, you might suggest he waive points to prevent any questions. Chuck
Excellent idea - and you guys say I never listen to you!
__________________
Butch Kummer
07-28-2010, 11:38 AM
Senior Member
A reminder - the car will have to meet SCCA safety rules for ITS. The Chief Steward is not allowed to waive tech items related to safety items in order to allow a car to compete.
__________________
Bob Hudson
Atlanta Region ProIT Chief Steward
07-28-2010, 07:07 PM
Senior Member
Shouldn't be any safety issues. Cage/fire bottle/kill switch, etc. safety rules all should line up with SCCA.
__________________
NC Region
07-28-2010, 09:30 PM
Member
Just have to remember E30 rules were built around common sense and practicality!! IT.....well......
__________________
Chris Leone
318i going ITB!!
E36 ITS underconstruction(sold)
84 944 ITS (sold)
71 240z more than half way there/now GT2 bound!!
ChrisLeonemotorsports.com
Roll cages and fabrication
07-28-2010, 09:52 PM
Senior Member
Originally Posted by DoubleXL240Z
Just have to remember E30 rules were built around one car......
Fixed that for you.
07-28-2010, 10:07 PM
Member
Thanks for that!! LOL
I was all over what you were saying on the other rant section!! Now you do this!!!
__________________
Chris Leone
318i going ITB!!
84 944 ITS (sold)
07-29-2010, 08:59 AM
Senior Member
Glad to help.
Point is that it's dead simple to write a rule set for a spec class. One can pick and choose whatever allowances one wants, based on parts commonly available in the aftermarket, to accommodate particular weaknesses of the chassis, or to make power in the cheapest way possible. It's just not that simple if we assume that lots of different cars need to be eligible and fairly classed.
07-29-2010, 12:04 PM
Senior Member
Plus, it's honestly hard to see any real difference in the fundamentals of the Spec E30 rule set and the IT ruleset. They are nearly identical.
__________________
NC Region
07-29-2010, 01:21 PM
Senior Member
NASA generally copied the GCR word for word with few exceptions. Cage rules included. However, NASA does require a center net (dated) and a dated window net, which expire. He should have no problem getting a SCCA log book. Butch, I assume you are talking about Jim Levie? Chuck
__________________
Chuck Baader
BMW 325e ITA
07-29-2010, 02:48 PM
Senior Member
Ends up the guy (whose name I forget right now, but he's from the Louisville area) already has an SCCA log book but lacks a current annual tech. We can take care of that Friday evening. He has also agreed to waive SARRC points as well (yes, if he's OOD he can't earn SARRC points, but he CAN take them away from someone else - by waiving them he has no effect on the SARRC standings).
I see where Jeff has signed up. Seems like the TR-8 with monster torque should clean up at Barber with its short straights and narrow line through the corners - beat everyone to Turn One and then drive the "defensive line" the rest of the lap!
__________________
Butch Kummer
07-29-2010, 03:41 PM
Senior Member
Butch
FYI
NASA Spec E30 cars are classed in ITS for the Northeast Pro IT series. We have a couple that have run several races and a few other visitors. They are all logbooked in SCCA and we have had no compliance problems. They are not in the front rank of ITS cars.
Terry
07-29-2010, 06:29 PM
Senior Member
Except I stink at driving that place. 1:48 is my best, been twice.
I have to find 3 seconds during the test day.......
__________________
NC Region
07-29-2010, 10:00 PM
Senior Member
I'll take out time from my build to be there...look me up and i"ll help you. Chuck
__________________
Chuck Baader
BMW 325e ITA
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
