Results 1 to 3 of 3
Thread: 71' ITS/Vintage Datsun 240Z For Sale
    Jul 2007
    8
    Default 71' ITS/Vintage Datsun 240Z For Sale
    For sale, 1971 ITS/Vintage 240Z with spares package.
    http://www5.snapfish.com/snapfish/thumbnailshare/AlbumID=11234966014/a=105487796_105487796/otsc=SHR/otsi=SALBlink/COBRAND_NAME=snapfish/
    to see pictures and a current VIDEO walk-around of this car, including engine run.
    AND: http://www.veoh.com/watch/v21007201HNKBaPyJ to see a full length video of the race car in competition action! I hope you will consider this car for your racing endeavors!
    Priced at $11,500 for the complete package. The car is located near Kalamazoo, Michigan. E-mail or call with any questions.
    Andy Cotyk
    269-484-4091
    Particular’s:
    Engine:
    · 1 race weekend on new rings/rods/mains/valve job
    · Compression:
    o 1 175
    o 2 170
    o 3 173
    o 4 170
    o 5 171
    o 6 169
    · 2.4L Bored .040 over
    · Early E-31 high compression Head
    · Comp oil pump and pressure springs
    · Top End Performance, stock cam/springs
    · ARP rod bolts
    · Nissan factory timing components
    · Daiken HD clutch/PP/TO Bearing
    · Rallye Sport (Jeff Winter) 6 into 2 competition header
    · Electronic distributor pickup
    · MSD Ignition/Blaster II coil
    Chassis:
    1. Competition Aluminum Radiator w/high capacity electric cooling fan
    2. Speedway engineering tubular (Nascar) front sway bar w/ adjustable heims
    3. Corbeau Seat with adjustable seat track and back brace (accommodates different height drivers)
    4. Tower Brace
    5. Koni 8610 series race shocks – Rebound adjustable
    6. 400F/325R springs
    7. Ground Control style suspension - Adjustable coil-overs, Camber Plates all 4 corners
    8. 3.7 welded diff
    9. 22 gallon Fuel Safe Race cell W/electric fuel gauge sender and dash gauge with low warning light
    10. Custom aluminum fuel cell cover with removable lid
    11. 3” Side fill external fuel filler port
    12. Dual Carter Fuel Pumps with Fram HP-1 filters and Fuel Safe check valves
    13. Sweet Manufacturing 15” quick release steering wheel and hub
    14. Dual EGT’s
    15. Ammeter, Oil Pressure, Water temp, Fuel Gauge
    16. Autometer Tach with max RPM record and adjustable rpm shift light
    17. 1-3/4” x .094” welded roll cage (Exceeds SCCA IT requirements)
    18. Nascar style door bars w/stripped door interiors
    19. Recent half/drive shaft bearings
    20. Scaled and aligned
    21. Tow Hooks F & R
    22. Master Kill Switch
    23. Fuel sampling port (SCCA required)
    24. BRE Style Spook W/Brake cooling air deflectors
    25. Night lighting W/ Dual Hella 3000 lamps
    26. Powered driver water dispenser
    27. Safety Fuel cutoff switch (tied to engine oil pressure) Master Panel
    28. 4 Speed trans w/recent synchro’s/brgs replace, double pinned shift forks
    29. Panasport wheels (4) 14”x7”
    30. Datsun Comp wheel studs
    31. Recent rear hub bearings/seals/packing. Penetrant inspected stub shafts
    32. Flowmaster Muffler/3” exhaust
    33. Energy Suspension bushings all locations
    34. Wink 4-Panel race mirror
    35. Brake bias adjuster
    36. New front race pads/1 race Carbotech rear shoes
    37. BRE style paint scheme
    38. Logbook since 1st race/Vehicle Title
    Spares:
    Ø Rebuildable stock 2400 engine
    Ø (4) Brand New Sticker Hoosier DOT racing radials
    Ø (4) Hoosier DOT racing radials (mounted on Panasport rims)
    Ø (11) Additional Hoosier DOT radials (various heat cycles)
    Ø (4) Hoosier Dirt Stockers mounted on Datsun aluminum rims
    Ø (Yes 23 total Tires!)
    Ø (1) 3.54 stock rear differential
    Ø (2) Rebuildable 4-speed transmissions
    Ø (2) Rear Half shafts
    Ø (1) Drive Shaft
    Ø (2) Rear Brake Drums
    Ø (Misc) Spare Fluids
    More……
    Attached Images Attached Images
    Nov 2005
    15
    Unsolicited plug:
    This is a great car, VERY well kept & competitive with an extensive race history. Andy is a straight up guy who has always been a pleasure to work with/for at the track. This car could not be duplicated with the included spares for this price, period.
    Jul 2007
    8
    The car has been sold. Will hit the Vintage circuit. A. :023:
Tags for this Thread
